cam LCD + ecran lcd 3,5" couleur 30€
- magic26
- votre campingcar : c25
comme j'y connais rien et malgre avoir lu toute la section je ne suis pas sur de mon choix
soit le tous a 29€ TTC port compris venant de uk c'est moitie moins cher que celui de pearl a 69€
avez vous deja achetez ce materiel
je pose me la question de la vision nocturne
et niveau fixation pour un montage en haut du c25 rehausse
merci pour votre avis
[url=http://img28.imageshack.us/i/sanstitre1jni.png/]
sur ebay 12€ + 17€ TTC port compris vennant de UK en 5/7J au lieu de chine en 15/21J + pb douane
camera 135/170 CMOS/CCD Car Rear View Camera E350
Made of high quality and durable material
High-definition and wide viewing angles
Support color CMOS/CCD image
Support PAL/NTSC TV system
With good waterproof function
With its elegant and contemporary design, this camera is very popular
Specifications:
Effective pixels: pal--628 x 586, ntsc--510 x 496
Shutter speed: 1/50 pal, 1/60 ntsc 1/10,000 seconds
Mini. illumination: 0.1 Lux/F
Video output: RCA connector, 1.0vP-P,75ω
power consumption: 110mA, max. 300mA wiht IR on
Power supply: 12V/24V
Operating temperature: -20°C - 90°C, RH 95%
Storage temperature: -30°C - 80°C, RH 95%
Lens angle: 135/170 degree
Color: Black
Package:
1 x One Camera
1 x One Manual
1 x One Connecting line (5m)
1 x power cable
ecran LCD couleur 3,5"
100% brand new,High quality
Screen Size:3.5 inch(4:3)
Resolution:640(H) x RGB x 480(V)
Model: PAL/NTSC (Automatic throw-over)
Power Supply:DC 12V
Visible Area:72 x 53.56
Power Consumption:0.53W
2-channel video input:V1/V2 auto switching(V1 display first)
Note:please Connect the Rearview camera's power cable with Reversing lamp,and connect camera's video cable with LCD's yellow cable(Video V1),then the LCD will show Camera's video when you are Reversing,and stop playing movie(auto switching)
Display blue screen on no signal.
Dimensions:107mm(L) x 80mm(W) x 15mm(H)
3.5" Car Rear View Monitor helps in preventing accidents while driving in reverse by avoiding children, traffic, pedestrians, toys and pets while backing out of the driveway or parking space
Specifications:
Color: Black
Package:
1 x One Camera
1 x One Manual
1 x power cable
Power Supply:DC 12V
C 25 serie2 blanc L2H2
- rémy
- prénom : rémy
- votre campingcar : sans
- Ville : LE MANS
Re: cam LCD + ecran lcd 3,5" couleur 30€
bonsoir ,
pourrais ton avoir une photo un peu plus grande , pour bien voir le kit ?
- magic26
oui pas de soucis je l'avais fait plus grande d'ailleurs je ne comprend pas pourquoi cela fait si petit ,ici
avec Hosting pics cela ne marche pas Jpeg ou png ils passent pas
je l'ai commande sinon 28€ TTc port compris vennant de uk colis partis hier
- rémy
- prénom : rémy
- Ville : LE MANS
re:
j'ai modifiée la grandeur de la photo , c'est un modèle genre lescar : http://www.campingcar-bricoloisirs.net/ ... ml#lescars
- magic26
merci pour le lien de montage en divers endroit tres instructif
le model lescar dont tu parle je l'avais comparer ( Pearl 79€ + port avec ecran 2,5")
la l'ecran est 3,5" avec 2 IN rca pour 28€ ttc
j'attend l'arrivée pour le test
- Lepreux
- prénom : SANS
- votre campingcar : sans CC
- Ville : PICARDIE
Bonjour, OK tiens nous au courant.A+
- rémy
- prénom : rémy
- Ville : LE MANS
re:
test avec photos si possible .j'attend l'arrivée pour le test
- prénom : Jean-Yves
- votre campingcar : RAPIDO 791FF DESIGN EDITION
- Ville : LOON-PLAGE
peux-tu me confirmer si tu as acheté ta cam en Grande-Bretagne et si tu l'a installé sans problèmes. Si c'est le cas aurais-tu l'adresse, à ce prix là c'est imbattable.
par avance merci de ta réponse.
- votre campingcar : lmc
BONJOUR
ON ATTEND AVEC IMPATIENCE DES NOUVELLES , ce sujet interesse beaucoup de monde , installation et addresse , j ai un cc de 8m20 , pensez vous que je puisse l installer ,?
Pour l'installation, vu la longueur de ton C.C, si le câble fourni n'est pas assez long tu devras vraisemblablement le rallonger mais bon ce n'est pas le plus compliqué. Je sais que certain équipements sont livrés avec un câble de 15 m, si le cas cas cela devrait suffire.
- penakrist
- prénom : Christian
- votre campingcar : Autostar Aryal 858
- Ville : TYhuir
il existe pratiquement le même avec transmission radio donc sans câble, un peu plus cher mais tout aussi efficace. Perso le mien viens des USA et en plus le receveur est solaire donc pas de câble non plus, seulement une connexion sur allume cigare lorsque' le camping car est resté longtemps à l'arrêt dans un garage (le chargement est quasi instantané). Ces systèmes sont aussi efficace que ceux vendus en concession et pour bien moins cher.
Qui veut voyager loin et longtemps, ménage sa monture.
Christian
Christian
- votre campingcar : CI MIZAR 150
pas de nouvelles ?
